96 codes and problems
ok so i just did the valley pan gasket new intakes upper and lower cleaned the heck out of the egr. put a used egr valve selonoid and mas air flow. Rear O2 Sensor are brand new and recently had new flex pipe welded in, ive been having some codes that cant figure out.
96 A4 Quattro 2.8 12v AFC engine code
in order on scanner
P1409 Tank Ventilation Valve Circ Electrical Malfunction
P1400 EGR Valve Circ Electrical Malfunction
P0161 O2 Sensor Heater Circuit Bank 2 Sensor 2
P0141 O2 Sensor Heater Circuit Bank 1 Sensor 2
P0155 O2 Sensor Heater Circuit Bank 2 Sensor 1
P0135 O2 Sensor Heater Circuit Bank 1 Sensor 1
in order on scanner
Maybe you missed something, or damage things when cleaning the egr valve. That almost always seems to be the case for me. Ive also bumped a vacuum line once sliding my hand down the side of my old Mazda's motor while wrenching, causing it to throw a code. Id check the surrounding area where you worked to make sure you didn't accidentally bump a wire loose. Hope this helps, just throwing suggestions at ya, good luck.
tripple checked everything took photos of everything before taking apart everythings all in good the codes were on before i did the manifold and egr i did those things hoping to fix the problem. All of the codes came up after getting a new flexpipe welded in. Car runs great like it should actually its runnin the best since i owned it, just the codes lingering though. i tested the diaphram of egr valve to so its all good
