96 a4 driver side window fell off track
Hello my a4 window fell off the track I know some of you have experience with this. I removed the door panel and I found a green broken clip that seems to attatch to the regulator. Can I just replace the broken clip? Or do I have to remove and replace the entire regulator?
I had this same problem in my car. I have seen just the clips on ebay, but everyy shop or store i went to told me the whole regulator must be replaced. Most likely to make money. But if you can find the clips im sure it can be done. I replaced my regulator with aftermarket and now when i roll the window up it will roll itself down sometimes.
Is this what you are talking about?
Audi B5 A4 Quattro 1.8T > Interior > Window > ES#10186 Audi Power Window Regulator Repair Kit - 8D0898015A
If so, I recommend a complete new regulator. It will save you a lot of headaches and repeat failures. Usually when the guide clip fails, the cable is shot too or the pulleys are close behind.
I agree with them. Replace the whole regulator.
