5 hours for oil pan gasket replacement?
Hey guys, does 5 hours for an oil pan gasket replacement seem about right? I'm just double checking. If 5 hours is the "standard time", I'm ok with paying that. Again, I'm just double checking.
Can anyone with experience chime in on this?
why are you changing it? 5 hours is $500 bucks, +++
you won't get out of there for less than$900.
well, with porsches, what's the diff? you either work on them or you don't.
Also, my indy used a "gasket sealer" silicone looking material. I.e. - there wasn't an actual "gasket" used. Does this seem right? I've seen actual gasket parts for our cars. But instead, they used silicone to act as the sealer.
Yep, that's correct. 06a blocks don't use an actual gasket. My valve cover is leaking as well but I've been putting it off because I don't feel like dealing with it myself and I don't feel like paying someone else to do it for me....
Might actually take you up on that when the weather breaks, I'm tired of cleaning oil off of everything.
Wow! 5 hours to change the oil pan gasket on a 1.8???
The first day I owned my '98 2.8l V-6, I hit a dip in the road down the street from my house a little too fast and cracked my oil pan. I think it took me about 45 minutes to change out my whole oil pan and gasket.
