4g63 450's on b5 a4 awm???
hey guys just recently came into a deal a buddie of mine is tryin hook me up with with a fmic and some stock 450 injectors from a 4g63 dsm. I was told that theres a way to run these on our cars. my car is an 01 a4 tqm with an awm engine. Could someone spread a lil info this way bc if i can use them then il buy them. but if not then yeah. So could some spread some incite. thanks in advance...
450's are quite a bit bigger than OEM. Adding JUST those will get you nothing except a poorly running motor without a tune/turbo/FPR/etc. Do you have anything else besides the injectors right now? If you're getting a really good deal on them it couldn't hurt to buy them and hang on to them, but injectors are definitely not a "bolt-on power" kind of mod for B5's.
Spray pattern is pretty important because 1.8T engines have 3 intake valves. Do you know what the spray pattern is like on those 450s?
Also, you may want to consider that there probably isn't a tune for 450cc injectors, unless you get an adjustable FPR and drop the fuel pressure a little so they flow the same as 440cc at 3bar fuel pressure. That is, if the 450s you're talking about will even fit...
of course guys this isnt my first rodeo , owned plenty of high horse cars in the past. just new to audi. But i guess i should have mentioned that this would be on a gt2871r, or gt30 turbo'd awm motor (havent decided yet) and with other supporting mods (pump,tunning, etc. ). Just didnt know if we can run those style injectors on our cars. And i guess also what style injectors are the oem. i know there 280's i believe but yea
Damn.. I never realized how small the 1.8t's injectors are compared to the DSM 4g63 injectors. I have a DSM myself and 450's are small as hell for us DSM guys. I'm currently running 1000cc's on my DSM. But there is really no reason to use them unless you are going to be running a bigger turbo. You also need a "chip" or some kind of retune to compensate if you change injector size. I can definitely see them being able to work on the audi, but there is no reason to use them unless you are going to be upgrading turbo, tune, fuel pump, etc, also.
You say you would spend $3-500 on "6's", does that mean you're looking for 630cc injectors? You can actually get Siemens 630cc injectors for $200 for a set of 4, and I think you would need rail spacers also which would cost a few $$ extra.
Where are you finding 630's for 200 bc everywhere I look there 300 or more
