240mm clutch/flywheel setup for A4 1.8t
240mm clutch/flywheel setup for A4 1.8t - Pics added.
http://forums.quattroworld.com/a4/msgs/38199.phtml
I was able to test fit the first one this weeekend and everything fit perfectly. So these kits are ready to go.
Pictures of a FX300 with the Billet Aluminum Flywheel
Pictures comparing the 240mm setup vs a 228mm.
CM 240mm Aluminum Flywheel vs a 228mm Steel Flywheel
228mm vs 240mm
228mm disk vs 240mm disk
228mm disk on 240mm flywheel
Kit features
*Ductile Iron Casting pressure plate surface
*Heavy Duty pressure plate cover
*2400 lbs Clamp load vs 1800 lbs for the CM 228mm kit
228mm vs 240mm
Kit features
Update - The Billet Steel option for this kit is no an added charge, so the kit is the same price with either the Aluminum or Steel flywheel. The steel flywheel is also 20 lbs vs the really light 11.1 lbs Aluminum flywheel. So anyone that wants a LWFW/Clutch setup that has no gear rattle and more hold then a standard A4 clutch then this is the setup you would want.
Video of the Steel flywheel has been added to the 240mm Clutch/flywheel product page on my web site.
Any insight on the hp ratings for these clutches?
Would it be safe to say you could run a 240mm fx300 in the same setup that would require a 228mm fx400? Also, what are the benefits of running the 240mm clutch/flywheel?
Comparing them together, the 240mm FX300 should hold about 120 tq/hp more then the 228mm FX400. I know guys running the 228mm FX400 on their built A4's pushing 350whp and have even launched them at the drag strip without a problem.
The 240mm kit uses a ductile pressure plate ring while the 228mm kits do not, this means it can handle way more heat since the grain of the metal is tighter. Not sure if you have seen a standard 228mm pressure plate crack, but I have had it happen twice and its not a pretty sight.
It also comes with a stronger pressure plate cover, stronger fingers, stronger flat springs(side springs) and more clamping load.
CM 228mm Pressure plate
CM 240mm Pressure plate
loves4
02-12-2008 08:45 AM
