2001 Audi A4 1.8t Quattro ECM Question
Can someone please give me a list of compatible ECM's that will work for my 1.8t quattro? I know for other cars it had to be pretty specific (such as same transmission, same drive trane, same engine(duh), etc), but I am looking to replace mine and I dont know what is safe to replace it with. It would be especcialy helpful if you give the part numbers as well. Thank you for your help. I am currently searching, but i am posting this just incase my search is inconclusive.
Thanks
Thanks
Trans code isn't important, but manual/automatic is. The ECU (or ECM, whichever way you'd like to call it) can be recoded in VAG-COM between manual and automatic transmissions with relative ease.
2001-2001.5 would be a 018CH and a 018M ECU. There might also be a few Passat ECU's that work too.
The 018M came in the early 2001 and the 018CH for the 2001.5.
The 2000 ATW came with a 018P ECU for the manual transmission(FWD and Quattor) and a 018Q for the Tip, the 2000 is one of the only years that you can not switch those 2 ECU's into the other car and can not be recoded to work in the other. Even the tunes for the 018P wont work in the 018Q ECU.
daze614
04-09-2013 03:15 PM
