2000 A4 with Stuborn Check Engine Light
Old 09-20-2011 | 05:08 PM
petemx5's Avatar
One more question - will I need a security code to get my radio to work again after I disconnect the battery?
Old 09-20-2011 | 05:17 PM
Skythe's Avatar
Definitely will. Try checking any manuals you have for it. There's a thread about getting a few guys getting the code from the dealer using their VIN, but I think the dealer might charge you. Another guy called Audi of America and got his code for free.
Old 09-20-2011 | 10:49 PM
Ryanwillbuyit's Avatar
Will this make my stock radio not work? Or have to get a code? (doing the battery way)
Old 09-22-2011 | 11:38 PM
Prmovers's Avatar
I am having a similar issue but my codes come up as misfire but the car is running great no hiccups or anything I am shocked the cel light stays on and I need to pass smog but every time I reset the lights theynreturn within 100miles of driving
Old 09-23-2011 | 05:55 PM
petemx5's Avatar
Well I might just give that a try beings I am out of time for having it inspected (was supposed to be done within two weeks of having it registered). Thanks CCA4.
Well, it worked...but the check engine light came on again this morning on my way to work. Was off for about 50 miles, ugh. And I didn't manage to get in inspected yet.
Old 10-04-2011 | 04:49 PM
petemx5's Avatar
Recieved my ECS V-Checker in the mail yesterday. Bought it online from TMart for about $78. Kind of psyched to see how well it works. I will post my error codes as soon as I have them, probably in a day or two.
Old 10-04-2011 | 09:01 PM
CCA4's Avatar
I have one of those and love it. Good luck
  #18
Old 10-06-2011 | 09:27 AM
petemx5's Avatar
Some History...
I recently bought a 2000 A4 Quatro Avant with a 2.8 V6 and auto trans. Love the car but within a few days of ownership the CEL came on. I brought it to an independent shop and they told me it needed two oxygen sensors and possibly new converters, but they wouldn't know that until they replaced the sensors. I had them replace the sensors but within a day or so the CEL reappeared.
I next took it to an AUDI dealer for diagnosis. They said they found some cracked vacuum lines, which they replaced and that the # 1 O2 sensor on bank two (drivers side) was bad. I went to PEP Boys and bought an OEM sensor (bosch) and replaced it myself. CEL did not budge.
Ok, I fired up the V-Checker last night and got the following 2 trouble codes (in generic mode).
  • P1176 Cam Calibration Fault
  • P0139.02 Sensor Circuit Slow Response Bank 1 Sensor 2
The second code looks to be another oxygen sensor fault (3 have already been replaced but I suppose it's possible that all four need replacement). I'm not quite sure what the first code means but I have read that the "1" in the third position means its a "fuel and Air Metering" related fault (it sounds like a timing issue?).
I also ran though some oxygen sensor tests but I don't know how to interpret the values. Here are the readings for Bank 1 Sensor 2.
  • Rich to Lean Sensor Threshold Voltage (constant) = 0.572 V
  • Lean to Rich Sensor Threshold Voltage (constant) = 0.572 V
  • Minimum Sensor Voltage for Test Cycle (calculated) Test Value = 0.000, Max = 0.572 Min = 0.000
  • Maximum Sensor Voltage for Test Cycle (calculated) Test Value 0.871, Max 1.004 Min 0.572
If anyone can help me interpret all of this or maybe identify what else I should be looking at it would be greatly appreciated.
Thanks,
Pete
RedA4guy
11-16-2012 03:43 PM
jseel
10-29-2010 12:34 AM
Firefighter6484
06-28-2010 12:26 PM
basementwaj
12-22-2007 04:21 PM
fastcarfreak
09-06-2006 04:28 PM
