2 piece Depo headlights
Ok so I’m at the junk yard this weekend when they bring out an A4, can’t believe my luck. Here is what I picked up; set of DEPO 2 piece projector Headlights with clear corners and a set of smoked side markers.
So my question is about the wiring setup for 2 piece headlights, I have used the search function only to find post for one piece conversions.
I know how rare of find they are......I hit pick a part every Saturday. The car was literally just put in the yard and I couldn’t get them off fast enough, paid $80 all I need now is the HID set up. I have seen your DIY (great one) my lights do not have a different style plug since the corner is separate, should I just follow your steps anyways?
Well, if the plugs are the same, I would alter the DIY slightly. The wiring job in the DIY was admittedly messy. A cleaner way to do it would be to plug the stock harness into your new 2-piece housings and then wire the HID's in from the inside of the housings. This will make for a much cleaner (and more waterproof) install
Thanks for the help.
Yeah I have the pre-facelift, wanted one piece but couldn't pass them up. I am going to switch out my stock headlight connectors on the depos, both depos have burned ground pins. I am going with a 35W 6K setup, should I use H7 or D2S lamps? The housing is marked D2S.
rawdney88
04-19-2011 10:51 AM
Emilgevor
09-07-2009 02:17 AM
