2 issues, are they related?
Note: I've searched.
Issue 1: Yesterday I made a 600mile trip and about 300miles into my trip my low oil indicator came on. I popped the hood and I checked my oil level, 1.5 quarts missing!!! I noticed the back of my 1.8t (near the firewall) was soaked in oil, so were some suspension parts just below. After adding the oil I stopped at the next service station (VW, there was no Aud) and I got them to take a look at it. They said I had a leak from the valve cover gasket near the cam seal.
Note: After adding the oil I was missing I finished my trip which was another 300+ miles and I didn't lose any oil at all!! WTF is going on? Is there something else in the back of the 1.8T that carries oil?
Do I need more than just the valve cover gasket kit to fix this leak or is it a bigger job since its from the cam seal area?
Issue 2: During my entire trip my temp gauge would drop down every half hour or so from normal (90) to cold (60) and then it would go back to normal after 5 minutes or so.. Thermostat? ECT Sensor?
Also, are these issues related?
Thanks in advance,
Michael
Thanks in advance,
Michael
RE: 2 issues, are they related?
yes the temp issue is the ECT, easy fix. my worry would not only be the valve cover gasket but also the rear main seal, chances are you were leaking oil and eventually the oil caused the seals to swell and better hold on to the oil you added.
ORIGINAL: B5 owns
Change the gasket, its likea 30 min job, then if you still get the problem, check the PCV system behind the engine.
