2.8l 12V - crank vent suction and seafoam - now O2 code?
Found a hole in one of the PCV hoses, also found the crank vent suction pump (the plastic Y) plugged (the side tube; 3rd one I replaced on various of my Audis).
Did seamfoam the intake through vac line, and sprayed TB as good as I can through the intake tube (MAF unplugged, corrugated intake hose removed).
Now showing code:
17514 - Oxygen (Lambda) Sensor; B2 S1
P1106 - 95-00 - Voltage too Low / Air Leak
Is that from the seafoam coating the O2 sensor? B2 S1 is upstream O2?
Will it go away or do i need to clean O2 (and how? burn with torch?)?
Now showing code:
boostedLTH
01-23-2023 11:47 PM
superdooperme
11-26-2008 10:53 AM
