2.8 V6 POLL - Voltmeter
Hey everyone,
If you own a 2.8L, what does your Voltmeter register while you drive? Mine sits just above 12, then drops to 12 and stays there.
Most other cars that I've owned stay above 12 when the car is running.
Thanks for the feedback!
Brought the car home and found the following wrong (there's more, but this is what I've corrected to date). Unfortunately, there's an electrical ghost that needs to be tracked down...
The List
- Bad Alternator with Bolt broken off in the engine block (that was fun)
- Bad starter
- Disconnected Ground Wire to the fuse panel
- Replaced lower oil pan gasket
- Replaced Valve Cover Gaskets
- Reconnected misc wires & hoses in the engine bay
