2.8 30v Twin Turbo
2.8 30v Twin Turbo
I'm running two GT30's on my 99 A4, its a 30v and I'm having a hell of a time finding any software what so ever for that motor. I'm currently running Megasquirt but it runs like ****. Anyone know of anything else I can run? Stand alone won't work, I have local "air care" laws and they need to check ports ect. Suggestions would be appreciated.
[IMG]local://upfiles/48666/281544C8D65F4C3BBE0262B9234BEAC0.jpg[/IMG]
RE: 2.8 30v Twin Turbo
nice cloud of smoke you got there - welcome to owning one of the worst cars to try to find anything for.
your only option would be to find a shop that would be able to do a custom tune for you. No one makes anything for the 2.8 engine that is worth the money.(besides PES or course)
seems to be running a little rich. That ic looks a little small unless your only running 7psi or less. BTW, you can run a standalone and make it pass emissions, you just need to do more work in getting it there. If you happen to be in the NE, there is a couple places you could go that i know of that could probably install and tune a EMS for you
I'm running at 16 lbs right now. That intercooler is very thick, which is next to impossible to see in the picture. For the emissions test here, the OBDII port needs to be scanable, is this possible with standalone?
I know you can pass emissions with a sem, so i would assume so. If you know a good tuner/shop, you can make it happen. If youare from either NY or PA, there is a couple shops i know of that have people that might be able to do the install and tune for you
