1999 A4 quattro 2.8l coolant leak
I have a ridiculous coolant leak on my 2.8q and when i went under to look at it it looks as if it was coming through the transmission? how much would that be to fix or is there any kind of way i can do it myself?
why should the tank and cap be replaced? i have 100k on my car and mine is original. should i replace?
My original coolant expansion tank started leaking at about 75k miles, and I had it replaced. That replacement tank started leaking this past spring at 123,000k miles. So now I have a new tank & cap, and I also took the opportunity to drain the old coolant and fill it with fresh G12 coolant while I was at it.
