1999 A4 1.8T - No Intercooler - Will the car screw up!
Old 02-27-2008, 02:17 PM
jasmix's Avatar
Default 1999 A4 1.8T - No Intercooler - Will the car screw up!
My front mount intercooler just messed up so Im back to stock piping but with no intercooler so from the turbo to the intake its just pipes...
will this mess the car? its a tempory thing untill I get the other one shipped
Old 02-27-2008, 02:22 PM
B5 owns's Avatar
Default RE: 1999 A4 1.8T - No Intercooler - Will the car screw up!
You should be fine, just try not to boost alot and drive very very carfully.
Old 02-27-2008, 02:24 PM
jasmix's Avatar
what happens if I do? will it not go over certain RPM's or its bad for the car
CLX's Avatar
CLX
CLX is offline
Zombie Defense Force
ORIGINAL: B5 owns
LOL
You'll be fine without the intercooler.
Old 02-27-2008, 02:25 PM
turbo kraut's Avatar
Tech Guru
most dsm's don't have them from the factory
Old 02-27-2008, 02:36 PM
01afour's Avatar
just keep an eye on your temp...im not sure the temp, id say around 250*, if its starts gettin hotter then that i would stop runnin for a while.
Old 02-27-2008, 02:48 PM
cincyTT's Avatar
I'm make believe
The temp is to way to hot if your not stock. if you arechipped, take a strait T peice and bypass the n75 so you run off just the wastegate (5psi).
Old 02-27-2008, 02:52 PM
jasmix's Avatar
cool got it!
Old 02-27-2008, 02:59 PM
CLX's Avatar
CLX
CLX is offline
Do you guys know what an intercooler even does?
Old 02-27-2008, 03:24 PM
cincyTT's Avatar
I'm make believe
No please tell me? If he runs with to much heat, he will have huge iat's and pull crap loads of timing and possibly damage his engine if the boost is to high. There is reasons why people that run non ic kits run really low boost
Quick Reply: 1999 A4 1.8T - No Intercooler - Will the car screw up!
