1996 Audi A4 2.8L Quattro Cruise Control/High Beam Issue
Old 11-13-2013 | 07:55 PM
zTougas's Avatar
Default 1996 Audi A4 2.8L Quattro Cruise Control/High Beam Issue
I have had the car for over a year and ever since buying it the cruise control and high beams have not worked. I was thinking that it might be the switch since they are both on the same one, but the turn signals DO work and are also on this switch. I wanted to know definitively before replacing the switch since it is a $300+ part. I thought maybe it was a fuse but I checked 18,19(high beams) and 31(cruise) and they were intact. I was wondering if it could be a relay? Or something else?
Old 11-13-2013 | 08:05 PM
markymarc's Avatar
Pretty sure it's the switch, if your bulbs are good. But, can't be 100%..... If you have a junk yard around, you could go find one, or find a used one....
Old 11-14-2013 | 02:06 AM
rshepler217's Avatar
I had the same problem with my 96 but the high beams were intermittent. Bought a used switch one off ebay and the problem was solved.
Old 11-14-2013 | 09:21 AM
mtroxel's Avatar
Very likely the switch. That switch is really about 10 switches in one, so part of it can go bad while the rest still works.
$300? That must be the dealer price. Bought a new one for my 99.5, was only about $150 at ECS.
Old 11-14-2013 | 10:26 AM
Clayson's Avatar
I have a switch laying around. If you want it, I can ship it to you!
Old 11-26-2013 | 09:03 PM
zTougas's Avatar
Clayson: how much do you want for it?
Old 11-27-2013 | 09:56 AM
Clayson's Avatar
I'd just want shipping covered, I'll PM you for the details.
Old 11-27-2013 | 12:20 PM
turbo510's Avatar
Try pulling back on the stalk; if the high beams come on, then the regular high beam contacts are defective. Either replace the switch, or take it apart to correct the problem.
The cruise systems on the '96 is often non-working, and usually either dirty contacts in the stalk switch, or a defective module. For the switches, spray WD40 into the crevices, and then cycle each button or slide switch to hopefully restore good contact. For the control module, remove the glove box for access to remove it. Then take the circuit board out, and inspect for obvious burns, cracks, etc. Sometimes just re-soldering the three red capacitors gets the module working again.
RayPag
12-26-2010 11:55 AM
AudiJarhead
B7 Models
08-27-2010 01:49 AM
Belligerenceā„¢
03-05-2007 06:24 AM
measeball
01-26-2007 12:46 PM
fastcarfreak
12-07-2004 05:05 AM
