18 inch rims?
#33
Post on Audizine says that size will work.
https://www.audizine.com/forum/showt...1#post10278902
What bolt pattern are those wheel and what car did it come off of? If a BMW, the bolt pattern and hub size are different. You will need adapters for the bolts and hub centric rings.
#34
Wheel spacer
It came from lexus GS 300, and also my concern is do I need to change suspension because of this or the stock suspension will still work???
#35
The bolt pattern is different. Are you willing to do adapters with this setup? (Going from 114mm to 112mm). If you are asking what adapters are then you’ll have to do some digging. They are also the wrong hub size. Strike 2. These wheels will not fit an Audi without wheel bolt adapters and hub centric ring adapters.
#36
#37
Best fitment for the b5 is an 18x9 wheel with the 225/40R18. Look for a +30 offset with a 5mm spacer
