16g turbo charger
Old 04-25-2008 | 12:47 PM
vms150's Avatar
Default 16g turbo charger
I have some history with wrx's and a fairly common turbo upgrade was the 16g turbo charger. I am wondering if that would be suitable for the 1.8t on the 2000-2001 a4 on stock internals and fueling with proper tuning. I am looking for some suggestions on turbo chargers and reading info. I am having trouble finding turbo upgrade information on these forums and am trying to read as much as possible before anything is decided. Thanks.
Old 04-25-2008 | 12:56 PM
explosionsteve's Avatar
Default RE: 16g turbo charger
looks at the stickies. "so you have decided to go BT" There is no way you are having trouble finding upgrade information, you just didn't search.
Old 04-25-2008 | 12:58 PM
Lazer Viking's Avatar
not again
kemp, is that you ?
Old 04-25-2008 | 01:01 PM
turbo kraut's Avatar
Tech Guru
here is kemps thread
and you really didn't search.... i typed 16g.... third post down
https://www.audiforums.com/m_799575/tm.htm
Old 04-25-2008 | 01:07 PM
vms150's Avatar
Thanks guys, sorry, im a noob. Thanks for the stickied info
Old 04-25-2008 | 02:14 PM
chaos92287's Avatar
https://www.audiforums.com/m_816714/tm.htm
https://www.audiforums.com/m_700266/tm.htm
unless you have the 16g lying around, i wouldn't use it
Old 04-25-2008 | 06:23 PM
ImTheDevil's Avatar
Probably the closest Audi equivalent to the 16g DSM/Scooby upgrade would be a K04 turbo, but honestly, you might as well spend a few more dollars and make a more significant difference in your output with a turbo of more capacity than a K04.
Old 04-25-2008 | 07:28 PM
cincyTT's Avatar
I'm make believe
How so? The ko4 wont make much over 200whp and thats beyond pushed and the 16g had more than made over 300awhp time and time again.
But yes, waste unless you just REALLY want to make your own manifold and downpipe
Old 04-25-2008 | 08:13 PM
mr.cAp's Avatar
ooohhhhh **** son, its gona be one of thoose ko4 threads again
Old 04-25-2008 | 09:04 PM
ImTheDevil's Avatar
My only point of the comparison really was that whereas the standard basic turbo upgrade for DSMs was the 16g, and for the Audi it was the K04. I know the 16g can make quite a bit of power (although I wasn't aware it made 300awhp), and obviously a lot more than a K04.
Quick Reply: 16g turbo charger
