1.8t vs 2.8v6
Old 06-10-2012, 07:24 PM
kriptonik's Avatar
Is this HondaTech?
Old 06-10-2012, 07:39 PM
02A6Beau's Avatar
i rilly dont no y all da peeples says this things bout da 2.8 it is bigger da nummer dan da 1.8 so dat mus meens dat is mor bester. jus git mor biger innercolers an da shining metl ntake
Old 06-10-2012, 07:48 PM
kriptonik's Avatar
LAWLOLLLLZZZ!! <3
Yup, AF is the new HondaTech.
Old 06-10-2012, 09:19 PM
ImTheDevil's Avatar
Speedtuning chip is a good mod on the 2.8. I drove Hiwords' car a few years ago, before and after he got it. Peak gain is small (maybe 5hp or so) but midrange gains probably 15lbs of torque - you can feel it. It smooths out the flat spot around 3k RPM, deletes the speed limiter, and I believe raises redline to around 7k. It's worth it.
Old 06-10-2012, 09:53 PM
IanWPB's Avatar
Are you going to go for it Jeremy?
I'm debating right now.. I've got lot's of maintenance stuff to take care of first. Tires for 600-700, trans mounts 100-120, trans fluid 50, brake fluid & power bleeder 100, etc. While I'm in there I might as well replace the brake lines with some stainless steel lines..
UGH.. I just want a little more power though..
Old 06-11-2012, 05:38 AM
ImTheDevil's Avatar
Unfortunately no. I need the car daily, and since the group buy was announced I've been watching the yard for 30v ECUs both for vgo and myself to use as stand-ins while ours got flashed and haven't had any luck. Had this happened earlier I'd have sent it out while I was on vacation back in April but it wasn't to be, this time anyhow.
Old 06-11-2012, 08:52 AM
jonbonesjones's Avatar
Moderator
should have said something we have like 6 0r so dead 30vs in our yard. i can imagine there would be one ecu in there
  #18
Old 06-11-2012, 09:38 AM
ImTheDevil's Avatar
Yeah I would've put the word out to join in but that money is better spent on other things right now, like a CV rebuild kit and tires.
