1.8T seafoamed and now not turning over????
I put some seafoam in my oil about 20 miles ago and today I put some in the throttle body and I takes. It was spewing white smoke (good) then it said ten the car off and put some more in the intake and wait 15 minutes, when I tried to turn the car back on it wouldn't start! Not only was it not starting it was turning over! It goes "Che ka" and stops!
On a 1.8T the vacuum line coming off the intake manifold at the front of the car should be a good place. On a 30v or 12v, use the line going into the suction pump under the solenoid bank at the top rear center of the engine, above the throttle body.
^What he said^
Just don't get scared if it doesn't turn over, just spray some gum cutter in there haha. I also took out all my injectors and seafoamed and brake cleaned them individually and replaced the caps/orings/screens. I didn't see much difference with the seafoam but I definitely saw it with the brake clean, cleaned all the crap out
Nevalite
08-13-2012 03:04 PM
