1.8 t No oil to head
Hi all, new to the audiforum. iv just bought a 1997 1.8t sport.
160,000miles, with the turbo missing due to smokeing.
laast owner said he had fitted a new oil pump the a week lata turbo went. if bought a new turbo, fitted it with new oil & filter, starts fine but top end is very noisey ( tapping) took off the oilcap when running & no oil on the cams, but no warning lights on dash, & Turbo feed has oil pumping through it.
can any1 help me. Thanks
Think iv found the problem, took the cam cover off, the chain tensioner has worn alot,
& is very high, i cranked it over & Oil was spilling out of it as its to high.
so the oils not carrying on to the cams & liffters.
Will fit the part tomorrow will let you know how i get on.
Heads nakerd, worn away cam bearings / seats. been offerd a head 1.8 20v Turbo, But the inlet ports are alot smaller, mine i can fit 3 fingers in, the other head im looking at i could only just fit 2 fingers in. is their to types of head.
It sounds like the head you've been offered is for the 1.8 20V NON-turbo. The 1.8T 20V TURBO head will be like yours: larger ports.
AudiTurbo
01-07-2014 08:03 AM
mikejones808
B7 Models
12-16-2010 09:42 PM
