034 puck valve
RE: 034 puck valve
it is a diverter valve, comonly know as a puck valve or 034 valve. part of the breathing componets for the engine. its circular in shape with two open ends in a L kinda shape. It's infront of the turbo.
RE: 034 puck valve
There is a DV AKA a bypass valve that releases pressure from the IC system and then there is the Puckvalve which is part of the crank case breather system. Which one are you looking for?
RE: 034 puck valve
im pretty sure hes talking about the pancake valve at the end of the crankcase breather tube that connects to the intake hose near the air filter
http://www.ecstuning.com/stage/edpd/...ategory=Intake
look all the way at the bottom of the page - OES - Pressure Regulator Valve - $26.32
MilitantGrunt
12-05-2011 12:15 AM
