01 a4, instrument cluster
i have a 2001 a4 1.8t and my computer screen in the middle of my instrument cluster isnt working anymore. does anyone know about this or have seen this before? it still displays what it should but is unreadable.
when you take it apart, there is a harness on top of the steering column right under the cluster. check that. also, many people have problems with pixels not showing up due to the heat. to solve that, people have replaced the super small wires on the harness to larger guage wires. that may solve your problem actually. so don't go buying a new cluster b4 you check those things.
how do you reset everything to match your cars specifics then? ie mileage ect.....
There is a procedure for this from VW/audi using the 1551/2. It's really sensitive and difficult, worse, you get 2 chances at getting it right before it's locked perminantly. Better to replace the failed part in the cluster with a known good one or, gasp... live with it.
