01 a4 1.8t engine code awm turbo not working?
Old 04-22-2012 | 08:56 PM
DanaB6's Avatar
Oh ok thanks, yeah the new turbo with this engine is rock solid feels brand new, i guess that could be it. I messed up pretty bad i googled cleaning MAF with brake cleaner and yeah..i see what i did wrong. I guess ill go to the shop tomorrow and order a new one and see how it goes. Do you think the bad MAFS could reuslt in me getting 220 miles on a full tank? instead of the 300+ I have no check engine light on.
Old 04-22-2012 | 09:02 PM
DanaB6's Avatar
is it normal for the whooshh sound to be really loud around 3-5k rpm?
Old 04-22-2012 | 09:27 PM
DanaB6's Avatar
just tested my 0-60 13 seconds. somethings wrong.
Old 04-22-2012 | 11:30 PM
Brochacho's Avatar
it would make perfect sense getting weird gas milage readings with a messed up MAFS because your car wouldn't be calculating air flow correctly, which would directly affect the amount of fuel being used.
Old 04-22-2012 | 11:32 PM
Brochacho's Avatar
Do you have the stock airbox filter, or did you put a cone filter in? Your Audi being able to breathe would most definitely make your car louder.
Old 04-22-2012 | 11:51 PM
DanaB6's Avatar
i have a stock box, i cleaned it and put in a brand new OEM air filter. It breaths loud (could be a leak im not sure) the thing is its really slow i noticed, 0-60 time is 13 seconds, and the car jerks like it struggling to go. followed with bad gas mileage (15mpg), and i noticed when i filled up last night i was at the stop light in neutral and the engine started vibrating kind of rough for a few second, i gave some gas and then it went away.
Old 04-23-2012 | 12:29 AM
Brochacho's Avatar
Dont hold this to me, but it sounds like you killed your MAFS. You may wanna look into that more.
  #18
Old 04-23-2012 | 12:38 AM
DanaB6's Avatar
Thats what im thinking, im going to go replace it tomorrow, ill update this as soon as i do it.
  #19
Old 04-23-2012 | 09:39 PM
DanaB6's Avatar
so i went and bought new a new bosch fuel filter and MAF sensor for $135, its actually the fuel filter, the cars body has 155k on it and the original owner never once changed it...its ridiculous, anyway i found out i need to drop the fuel tank a little to remove the fuel filter so i wasn't able to do it today. Im going to do it wensday morning and replace both. Ill probably need to replace the fuel pump also.
xristos.greece
08-13-2017 08:24 AM
TurboB6
12-19-2010 08:51 PM
A6 Quattro V6 30V
08-06-2010 02:06 AM
10kRedline
05-06-2010 06:29 PM
MilitantGrunt
11-01-2006 09:16 AM
Quick Reply: 01 a4 1.8t engine code awm turbo not working?
