"High Performance" Intake
Old 04-18-2007 | 04:39 AM
B5luver's Avatar
Default "High Performance" Intake
Hey everyone, I'm attempting to make my own inlet tube with a cone filter, and what not. I know I know, I'll lose power but not the way I plan on doing it. Any how my question is does anyone know where I could buy a tube or part similar to the metal tube in this link: http://cgi.ebay.com/ebaymotors/ws/eB...731&rd=1,1
The tube with the flange to relocate the MAF. Thats what I need is to relocate the MAF. If anyone could help me out I'd greatly appreciate it.
Old 04-18-2007 | 04:42 AM
Jeff's Avatar
Zombie Defense Force
Default RE: "High Performance" Intake
you could just use the whole maf assembly and connect 2 silicone hoses one to each side
Old 04-18-2007 | 04:53 AM
B5luver's Avatar
well I know that, I'm just trying to get the most airflow possible obviously, happen to know the diameter of the OEM MAF assembly?
Old 04-18-2007 | 05:05 AM
Jeff's Avatar
well you want to use the stock maf houseing or one the same size because it is scaled to use that diameter of pipe. and the plastic things are there to straightn out the incoming air. the stock maf dosent need to be larger. i made 337whp on a stock maf.
Old 04-18-2007 | 04:20 PM
LampyB's Avatar
Do you have to get a custom heat shield in order to use this air filter mod? i'm worried the inlet pipe and air filter being outside of the box will get too hot...
as posted above, here is the ebay kit:
Thanks...
LampyB.
Old 04-18-2007 | 04:50 PM
akoby9's Avatar
^Yes you should make or buy a really good custom heat shield otherwise you will be pulling super hot air.
When I first installed mine I used the OEM heat shield and then after I made my own heat shield I could tell a MAJOR difference from pulling hot air to cold air
Old 04-18-2007 | 05:04 PM
Boostfed13's Avatar
Here you go
http://www.modshack.info/bamm.htm
audiSfour
B8 Models
11
04-17-2013 10:21 AM
ozzydog
07-25-2011 07:15 PM
cincyTT
05-29-2008 06:55 PM
phitau09
02-05-2008 09:09 PM
