Where is the filler plug?
2003 TT with 180hp motor, Tiptronic auto trans
After having a bit of trans trouble, and because several posters mentioned replacing fluid & filter, i ordered a kit from Blauparts. Now I've got it but I'm stuck - cant find the filler plug on the trans.
An old post here indicated the drain port & fill port are the same - but I'm not buying that because there are separate parts in this kit for each.
I'm not draining this thing until i _know_ I can refill it - so can anyone here give me a clue as to where the filler plug is located?
It might be worth buying the info from Alldata. it does show a separate drain plug but i usually just pull the pan down & drain into oil drain.
The plug in the pan is the inspection hole for the fluid & in most cases the same spot where the fluid is filled into. It also involves monitoring transmission temperature with a scan tool that has the capability to read transmission data(Vag-Com is my tool of choice most of the time).
One more thing is that when transmission fluid levels are checked the vehicle Must Be level!
werkwitdis
06-04-2006 02:07 AM
