Wheel Spacers
RE: Wheel Spacers
ORIGINAL: MeanAudiA6
dont laugh but my konigs didnt come with them at least i dont think they did can i get them from the discounttire place where i got them? or do you think i have to order from konig?
RE: Wheel Spacers
ORIGINAL: Bigrigatoni
Never mind Steve, I found them. They're called Spigot Rings. We use a 57.1 mm. I'm going to a local aftermarket wheel shop tomorrow!
RE: Wheel Spacers
Ok im getting confused... before I put the spacers on, my car was already missing the plastic ring and the ride was fine. but now its bouncy. but here is the thing, my spacers hubcentric ring is not flat like the pic posted or like the stock hub, my spacers have a thick curved ring kind of like the shape of the plastic part. So do I need the plastic ring on my car? if I remember right,on the wheels t5hat have the spacers one of themhas a plastic ring and the other does not.
RE: Wheel Spacers
I bought mine from a local Wheel shop.I had to call my wheel manufacturer (ROJA)toget the I/D of the hub. You have to find out what size you are fitting into from the 57.1mm..... $20 for the set. Are you having vibration now with the stock wheels and spacers??
RE: Wheel Spacers
REMEMBER... most wheels are "hub centric" where you rely on the center hub to align the wheels as opposed to "lug centric" where you use special bolts to align the wheels. Using hub centric wheels without the hub centric rings, you will almost always end up in a situation where the wheels are off center and create vibration.
RE: Wheel Spacers
