wheel spacer q
Old 07-06-2008 | 03:05 PM
ooTToo's Avatar
Default wheel spacer q
Hey guys, as some of you know by my IM's, I am looking for some wheel spacers. I have a couple questions..
1) I have stock suspension with Flik Justices (8inch & 35offset) and the calculator says 19front and 25rear. I just wanted to know if anyone out there has some setup like mine and if it will be flush, or what you might recomend?
2) Can I mix up spacers? I cant really find anyone with both sets I want, so i want to know if i can get an H&R front set and some other brand for the rear?
3) What do I want.. hub centric or non ?
4) Does this mess up my camber at all ? Do i need a k-mac kit or anything else?
Old 07-06-2008 | 03:22 PM
exTTreme's Avatar
Default RE: wheel spacer q
I'm pretty sure there is no reason you cant use different brands of spacer for front and rear
I'm pretty sure you want hubcentric
I have no clue on the camber
Old 07-06-2008 | 03:31 PM
.clipse's Avatar
SoCal Crew Member
^ camber/toe are hand in hand, and only starts to bend negatively when the car is progressively lowered. you dont have to worry about camber w/ spacers.
and ofcourse you want hubcentric spacers.
Old 07-06-2008 | 04:09 PM
ooTToo's Avatar
great, thanks !
now any clue on where i should go with size ?
Old 07-06-2008 | 08:45 PM
.clipse's Avatar
SoCal Crew Member
ok flik justices are usually at a 8" width at et+35...
id go 20mm fronts, 25mm rears. it wont be "OMFG FLUSH" but real close.
Old 07-06-2008 | 09:16 PM
ooTToo's Avatar
oh snap.. on vortex someone said they had 8" 35offset with 16mm / 20mm and they were flush.
i want them pretty flush, i dont want them still inside, but i dont want them out at all.. it sucks cause they arent cheap and you cant really return ! [:@]
connor
12-17-2012 06:54 PM
MYH8for405
06-20-2007 05:59 PM
tip5
12-19-2005 08:33 PM
black991.8tq
02-21-2005 05:21 PM
Honda882000
02-15-2005 02:22 AM
