Wheel hop?
RE: Wheel hop?
Definition: An undesirable suspension characteristic in which a wheel (or several) moves up and down so violently that it actually leaves the ground. Wheel hop can be caused by many problems, including excessive unsprung weight, insufficient shock damping, or poor torsional axle control.
RE: Wheel hop?
Drag racing starts;rev the engine real high, dump the clutch, and your wheels will jump up & down (partly) because of engine movement, resulting in a loss of traction. If you want better traction when doing this then you need the kit.
RE: Wheel hop?
ORIGINAL: Dana Reed
RE: Wheel hop?
yet another drag artistnow why would you ask this question here or was it a copy from AZ?? im beginning to wonder if the forum is part of the said because most questions pertain to mods rather than real problems??????
RE: Wheel hop?
ORIGINAL: avant80@2.6
actually my car is making a hollow howling noise at 3500-4500rpms in all gears. almost sounds like what the vtda soundclip only i have a stock airbox. if i push the clutch and keep the revs at 3500-4500 the sound is not there.
thoughts?
RE: Wheel hop?
ORIGINAL: diehlryan
isn't this a good thing? means no one is having problems.
thoughts?
thoughts?
