water meth group buy at vwvortex
I am too poor, but maybe some of you arent haha. Just wanted to make sure you guys knew about it, some good discounts.
http://forums.vwvortex.com/zerothread?id=3513264
RE: water meth group buy at vwvortex
You really should get a maf kit unless you dont plan on running one. The maf will inject the proper amount faster since it is preactive and not reactive. This means the MAF will see what it needs first where the MAP wont see it until you make the psi, which is a little late.
but the maf has a much higher rate of failure. plus the snow performance ones are all going MAP now? or at least thats what i thought.
i see what your saying, i figure MAP will be more consistant since its just a pressure reading, i think the controller sold by snow does min 8 psi and max whatever you like,.
