Is waste gate normally open
Old 12-11-2010 | 01:37 AM
phatboyfromla's Avatar
Default Is waste gate normally open
Is the wastegate normally open then it's closed by the N75 to allow boost? 2001 Quattro 225 AMU Type
Old 12-11-2010 | 01:05 PM
cincyTT's Avatar
I'm make believe
If its in your hand, it should be closed. The wastegate is open when in vacuum and then closes when you go wot and then opens again when the psi setting is reached (well, creeps open before that) to keep it there
Old 12-11-2010 | 01:54 PM
Thanks for the reply. Guess I'll do another leak test. Don't think my N75 is reading correct resistance either. My meter has X10 ohm setting and when I test across the N75 is goes to 1 which I'm assuming would be 10ohms? Thanks again.
browny355
05-27-2011 11:04 AM
Pazza
06-05-2009 03:50 PM
theguy1084
06-27-2007 12:12 AM
beast a4
05-04-2007 10:43 PM
True_Pinoy
08-03-2006 06:07 AM
