Velocity stack
Old 07-23-2007 | 06:43 PM
auditt225's Avatar
Default Velocity stack
So I was wondering in since I already have an intake, Im just going to buy the air intake duct and put a velocity stack in front of it. Just like a homemade VTA from modshack.Does anyone have any questions about it? Should I do this or not? Also when modshack first came out with the VTA it came with an insulator instead of the canister. Can I do that as well? Im sure I can get it from lowe's or home depot? Just let me know what you guys think. Thanks
Old 07-23-2007 | 06:51 PM
cincyTT's Avatar
I'm make believe
Default RE: Velocity stack
I SEE IN YOUR FUTURE.......spending money and not seeing any difference in performance, good luck though
Old 07-23-2007 | 07:13 PM
gravitt's Avatar
Agreed. Intake provides minimal performance gains-- mostly it'stheimprovement in throttle feel and louder DV sounds that an intake mod will help.
Old 07-23-2007 | 08:23 PM
.clipse's Avatar
SoCal Crew Member
^ hey my TT felt a bit more torque-ier when i put in my vtda. **** sounded like a boxer engine at first
Old 07-23-2007 | 08:34 PM
joshuo's Avatar
^^^ lol @ cincy!
Old 07-24-2007 | 09:09 PM
achTTung's Avatar
you want velocity stacks, do it like this..
http://www.elitedubs.com/index.php/topic,2275.0.html
Old 07-25-2007 | 12:45 AM
racer_x's Avatar
intake will help, get chipped first. if you're ultra-low-budget and not going to shell out the bucks to chip, do the "diode mod" ... do a search for it on the forums. Intake is a great upgrade-- if you asked any of the modders on here if they had stock intake, most would look at you like you were crazy.
slight HP gains stock, more chipped. Better sound, but careful if you're doing it in your garage-- you don't want to be sucking in hot air, so do the insulation and heat shielding properly.
Good luck!
Old 07-25-2007 | 01:03 PM
.clipse's Avatar
SoCal Crew Member
you could always do the airbox mod as well. bore at the bottom of the air box and put a k&n drop-in.
Old 07-25-2007 | 03:02 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: racer_x
Good luck!
he has just about all the bolts on there crazy
mctavish11
03-03-2009 02:01 PM
fadeoutmystar
08-10-2008 12:44 AM
PCBOI808@HOTMAIL.COM
08-13-2007 01:21 AM
Blown87camaro
05-10-2007 05:16 PM
peterancona
04-18-2007 08:09 AM
