Vacuum Hose Kit?
Old 09-09-2007 | 03:22 AM
Anos's Avatar
Default Vacuum Hose Kit?
Do any of you know of a company that has a complete Silicone Vacuum hose kit for our cars? Was talking to a reputable Foreign car place around here and he claims the cold start issue could be due to smooshy/cracked hoses someplace outta sight. On ECS I see they sell Silicone Hoses in 1' Increments which is cool - A kit would save me some headaches since I don't know all the vacuum lines Just yet hehe.
Ill keep browsing around and see what I can dig up - Thanks ahead of time
Old 09-09-2007 | 07:44 AM
neur0tic's Avatar
Default RE: Vacuum Hose Kit?
scroll about half way down this thread. There's a photo of an engine bay with hose sizes all labeled.
https://www.audiforums.com/m_604957/tm.htm
3.5mm
6.0mm
8.0mm
Also, hightempsiliconehoses.com has a huge selection of different types of silicone hoses in like 5-6 diff colors. diff types of silicone for diff needs. Plus they have all three of those sizes.
Old 09-09-2007 | 01:03 PM
MeanAudiA6's Avatar
http://hosetechniques.com/
Old 09-09-2007 | 02:24 PM
theTTkid's Avatar
anyone have hose size diagram for a 180-- that was a 225 so idk if its different or not
Old 09-09-2007 | 02:51 PM
MeanAudiA6's Avatar
same just get the universal starter kit you will a lot left over
Old 09-09-2007 | 03:01 PM
quattro411's Avatar
i dont see any universal starter kit, do you have a direct link?
Old 09-09-2007 | 03:04 PM
quattro411's Avatar
i take that back, site is a little hard to navigate
Old 09-09-2007 | 07:16 PM
Anos's Avatar
Woot TY - Ordered the silver starter kit - not a half bad price either - Hopefully it cures the problems i've been encountering
Old 09-09-2007 | 07:59 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: theTTkid
ATC cars
1 - Vent line
From gravity valve at fuel tank See "Fuel Tank, Removing and Installing" item no 8. See: Fuel Tank\Service and Repair
2 - EVAP canister
With Evaporative Emission (EVAP) canister purge regulator valve -N80-
3 - Turbocharger
4 - Check-valve
For EVAP canister system
5 - Pressure unit
For Boost Pressure Regulation Valve
6 - Deceleration shut-off valve
7 - Wastegate bypass regulator valve - N75
Valve is activated (pulsed) by the Engine Control Module (ECM)
Checking activation: See Output Diagnostic Test Mode (DTM), activating. Refer to "On Board Diagnostic". See: Computers and Control Systems\Testing and Inspection
8 - Brake booster
9 - Check-valve
For brake booster
10 - Air filter with Mass Air Flow (MAF) sensor - G70 -
11 - Pressure control valve for crankshaft housing ventilation
12 - Combination valve
For Secondary Air Injection (AIR) system
Checking. See: Emission Control Systems\Air Injection\Testing and Inspection
13 - Fuel pressure regulator
14 - Check-valve
15 - Recirculating valve for turbocharger -N249-
16 - Secondary Air Injection (AIR) solenoid valve -N112-
17 - Crankcase ventilation
18 - Check-valve
19 - Charge air pressure sensor -G31- / charge air cooler
20 - Secondary Air Injection (AIR) pump motor - V101 - *
Checking function. See: Emission Control Systems\Air Injection Pump\Testing and Inspection
21 - Vacuum reservoir
aww/awp cars
Turbocharging System, Overview
1 - Vent line
From gravity valve at fuel tank.
2 - EVAP canister
3 - Turbocharger
4 - Check-valve
5 - Pressure unit
8 - Brake booster
9 - Check-valve
For brake booster
14 - Check-valve
18 - Check-valve
redmond1501
05-12-2014 03:55 PM
generik777
07-27-2009 10:29 AM
sanjay.debian
12-26-2007 07:32 PM
Audi42005
05-12-2006 03:03 PM
a4autocrossr
07-15-2005 07:06 AM
