v checker readouts
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
i just did a service read with a v checker an this came up
P16684, p0300 random/multiple cyliner: misfire detected
p16687, p0303 cylinder 3 misfire
p16688, p0304 cylinder 4 misfire
17608, p1200 recirculating valve for turbon249
16955, p0571 brake switch a circuit, malfunction
18010, p1602 power supply (B+) terminal 30:low voltage
17536, p1128 bank 1 mixture adaptation (mlt): system too lean
00283 speed sensor or front left g47
00588 airbag igniter - driverside -n95
01218 side airbag igniter pass side n200
i recently changed the coils and sparkplugs.
i recently had the driver side front wheel bearing replaced.. not pressed , hammered. my abs and traction control light are on.
i removed the driver side air bag to change the signal stalk air bag light came on after reinsall.
2001 audi tt AWP FWD 1.8t
a lot of codes there, airbag it seems you didn't follow procedures and pictures to show you how,
other codes could be bogus stored codes and need clearing,
ABS and you hammered the bearing in? that's not good practice ( did you remove the ABS sensor intact and the ring gear ) most have a cog/gear type fitting and toothed so if you damaged that the ABS and any other system linked to it will fail ( 00283 speed sensor or front left g47 ) and the unit will need replacing
# I hate this vista stuff because it complicates thing ill have ro get to know it better[:@]
[IMG]local://upfiles/12092/15BEC0820442436C83045485F7F15022.jpg[/IMG]
[IMG]local://upfiles/12092/ACA0773B5DD04BC3AA97BA927A54C646.jpg[/IMG]
[IMG]local://upfiles/12092/EEB36CD343024D919BC17CB7B0830461.jpg[/IMG]
