Upgraded Plug Wires ???
Old 05-07-2007 | 06:38 PM
Justin_72's Avatar
Default Upgraded Plug Wires ???
I saw the how-to on making your own performance wires the other day, and thought it'd be a fun and easy upgrade. Before I do it, I had a couple questions. First, what size are the stock wires? Previous performance wires I've had were 10mm. Second, how easy/hard is it to get to the wires on the TTs? I know some cars are cake and others are a biotch! Any info is greatly appreciated as always!
Old 05-07-2007 | 06:48 PM
cincyTT's Avatar
I'm make believe
Default RE: Upgraded Plug Wires ???
If you dont have a stand alone ems, you have to use the coil packs.
Old 05-07-2007 | 08:55 PM
bahndrvr's Avatar
Not even worth considering, you have coil on plug setup, there are no wires like your htinking about. You would need a standalone as Cincy said or I've seen some custom jobs done with the old VR6 controllers but the effort is not worth it, Ignition Solutions has a nice setup if you just really want to spend money on ignition, but it will be at max about 5-7 horsepower and close to 1000 bucks when all is said and done.
Old 05-07-2007 | 09:05 PM
cincyTT's Avatar
I'm make believe
he just wants to be cool with one of these
Old 05-07-2007 | 09:59 PM
sheepcan's Avatar
Can you upgrade your coil packs?
Old 05-08-2007 | 02:57 PM
cincyTT's Avatar
I'm make believe
If you dont have them, get the Hitachis
Old 05-08-2007 | 03:08 PM
twenty8red's Avatar
how can you identify the coil packs? do you have a part number for the hitachis? what are the benefits?
Old 05-08-2007 | 03:11 PM
diehlryan's Avatar
ORIGINAL: cincyTT
Ivote this as the most used picture on AF's TT Forum.
Old 05-08-2007 | 03:27 PM
cincyTT's Avatar
I'm make believe
Its so ugly and has a bov and turboxs mbc peeking on the side, EEEWWWW! It would be worse if you could see the catch can on the side, that god the engine cover is blocking it!
Old 05-08-2007 | 03:48 PM
diehlryan's Avatar
ewww and i just noticed inside the audi rings is unfinished.. needs painted red.
and your TB and Intake Manifold look just as grimey as mine.
I know someone with a polished intake for a 180 for sale.. what would a good price be to offer?
