Uneven brake wear
Old 06-05-2007 | 02:37 PM
Palindari™'s Avatar
Default Uneven brake wear
Just put Power Slot slotted rotors and and Hawk pads - pretty easy install (thanks to all that have posted on here) but now I have two questions...
Slight grinding from the front (was told that this will be normal for a week or so...)
and uneven wear - the left side rotor is clean - the left is patchy like it's not grabbing properly.
I've searched and have yet to find any reference to this
left side - normal wear (after about 60 miles of driving in the city)
right side - abnormal wear...
Sorry - focus is off - but I think you get the picture...
Pedal is responsive - no spoungy feeling. Bled the brakes just incase this morning - all seemed good.
Is this normal for breaking in?
Old 06-05-2007 | 03:01 PM
cincyTT's Avatar
I'm make believe
Default RE: Uneven brake wear
dont think those pads are seated right. Also does your car pull to one side when brakeing?
Old 06-05-2007 | 03:38 PM
Palindari™'s Avatar
Nothing noticable upon braking - slight leftward drift - but that was there prior to the brake change... I'll pull it apart again and check
Old 06-05-2007 | 03:53 PM
techbod's Avatar
which way round is the right side going? looking at you pictures they point >>>>>> for each picture if so the disc is for the other side or you have 2 left discs/rotors just a thought
Old 06-05-2007 | 03:55 PM
cincyTT's Avatar
I'm make believe
his disc are right. thats the way powerslots go (i had them on my last car).
Old 06-05-2007 | 04:01 PM
techbod's Avatar
hmmmm so what is the rotation of them ( is the first going forward>>>>>> and the last going forward <<<<<<<<<,
surly going forward the slits should face //// ?
Old 06-05-2007 | 04:09 PM
techbod's Avatar
[IMG]local://upfiles/12092/5A8B8B58C27D4D7E8069F2DAA4B6A12D.jpg[/IMG]
[IMG]local://upfiles/12092/44E6F82C796B44B7A5209387F73D7F3D.jpg[/IMG]
Old 06-05-2007 | 04:34 PM
Palindari™'s Avatar
the lower part of the slot should be towards the front of the car
Old 06-05-2007 | 04:45 PM
techbod's Avatar
so the bottom one going forward <<<<<<< and top going forward >>>>>>> and looks like there is something lodged on the pads ( I assume you put new pads on? ) and lubed all the parts up so the caliper moves freely
tom225
03-15-2013 04:10 PM
mtboulder
05-04-2009 12:28 AM
C_TAYLOR
05-07-2008 12:32 AM
krishcanag
01-27-2008 12:23 PM
duburban
12-10-2006 06:11 PM
