Under load AFR is really rich... 9.3. Tips to bring back to target of 12?
Under load AFR is really rich... 9.3. Tips to bring back to target of 11?
My Uni file has always seemed to run rich, and now at I have added a wideband and can monitor it, I can see that it def runs rich while under load, usually to the tune of 9.3.
My idle afr is pretty consistent between 14.5- 14.9, it fluctuates a bit. I assume this is common for all cars, but this is my first time with an afr gauge to watch it all the time.Partial throttle runs a bit richer, but I see the 9.3 all the time when getting on it.
Based on my searching and reading in this forum, if I adjust chan 2 in Unisettings, that should help me get my afr back to around 11 or so, correct? Will that adjustment have an affect on the idle afr?
How much should I adjust at a time while trying to get to the target area?
Thanks for your input.
edit for afr target typo
