Turbo problem ~ prob need a new one
RE: Turbo problem ~ prob need a new one
the small cylinders where the hose came off is just behind the lower bumper grilles in front of each tire.The hose connected to the one in front of the passenger tire came off. I'm almost positive its not the turbo. I can't seem to find any more loose hoses. BTW - where is the turbo located on the TT?
Bet thats the base of the headlight washers.
Turn your headlights on, and then hold the washers on for a couple seconds, you should hear a loud buzzing, and see water spray on your headlights. if one of those hoses are off/broken, you'll just dump washer fluid on the ground. Pretty obvious way to find out if thats your problem.
