tube from top of turbo to large metal 90 degree pipe?
What's the tube called that goes from the top of the turbo (output)to the large metal tube on the top of the engine? I can't seem to find a reference to it in the manual or on any of the parts websites.Therubber tube itself is covered with some kind of heat shielding.
Thanks!
Ian
Thanks!
Ian
RE: tube from top of turbo to large metal 90 degree pipe?
ORIGINAL: cincyTT
its just the turbo outlet hose. It really doesnt have a name. Do you need to replace yours or something?
This one: http://www.forgemotorsport.com/conte...roduct=FM225TH
I finally found it in the manual, but it looks very different from this one. I'm pretty sure that there's a leak somewhere, cause I can hear it when I rev the engine. Sounds like a hissing noise.
yup and i have it. its kinda a biatch to remove. hint-remove the strut tower bar...gives you more access to work. and make sure you get the new one on snug and using soapy water helps lube it going on.
MolinAudi
04-14-2010 11:58 AM
