tt upper grille install
RE: tt upper grille install
There are several screws along the top under the engine compartment trim. You also have to remove or pull back the wheel well liners, there are two 10mm nuts that have to be removed on each side. You'll need a 10mm deepwell socket and an extension to reach those. Then there are two Phillips screws on the bottom of the cover. After all of that, just lift it off.
