tt ko3-ko4 help
Old 06-10-2007 | 11:57 AM
oris's Avatar
Default tt ko3-ko4 help
Ok, I have a 2000 TT with the stock KO3 turbo I would like to install a KO4 turbo, I want to kown what I would need to do the install. I also have a Giac solder-in chip that was installed about 5 years ago with the first owner of the car, the car runs about 17lbs of boost, would I also need a software upgrade or is what I got go enought?
Thanks for the help!
Old 06-10-2007 | 12:03 PM
cincyTT's Avatar
I'm make believe
Default RE: tt ko3-ko4 help
ko4-001 is a direct install. It is smaller than the ko4 in the 225 and is only good for about another 15-20 over a ko3. It will however hold boost longer than a ko3. You can leave your chip in place, but a upgrade wont cost to much.
for a ko4-2x from a 225 is not a bolt on. you have to get a new manifold along with other parts. go to www.pro-imports.com. they have full kits available there. good for abouth ~40hp
Old 06-10-2007 | 12:24 PM
oris's Avatar
Thanks, also with the KO4-2x would I need to change my software or is it fine to use? What software file from Giac would you recomend?
Old 06-10-2007 | 12:33 PM
cincyTT's Avatar
I'm make believe
you will need 225 injectors or some 380cc and sw written for it. Just ask the closest dealer what they can get for you.
Old 06-10-2007 | 01:34 PM
225tt's Avatar
Or just go Big Turbo!
Old 06-10-2007 | 04:19 PM
cincyTT's Avatar
I'm make believe
for about the same cost as a ko4-2x, you can get a t3s60 or 50trim setup and get real power.
Old 06-10-2007 | 04:21 PM
225tt's Avatar
Yep yep, he knows his stuff!!!!
Old 06-10-2007 | 10:44 PM
theTTkid's Avatar
i wish i was cincy smart... shoot[]
Old 06-10-2007 | 10:52 PM
cincyTT's Avatar
I'm make believe
lol, dont know where that came from
