Trunk Lights don't Work?
Old 10-29-2008 | 08:41 PM
joshuo's Avatar
Question Trunk open sensor???
Hi all.
My trunk lights don't seem to work. (trunk open, lights on)
You know, the one near the warning sign (don't smash people's heads in) in the hatch,
and the one on the left side of the trunk, near where the Amp is?
I checked the bulbs and they are fine.
Fuses seem ok.
What is going on?
Last edited by joshuo; 10-30-2008 at 08:13 PM. Reason: Problem is not with the lights.
Old 10-29-2008 | 09:10 PM
joshuo's Avatar
Update:
I found the culprit.
The car doesn't 'know' that the trunk is open.
Faulty microswitch? where is it located?
thanks
josh
Old 10-29-2008 | 09:30 PM
myxyzxo's Avatar
SoCal Crew Member
Mines doesn't come on either. Unless I turn the hazard lights on.
Old 10-30-2008 | 01:48 AM
myslow1's Avatar
i just noticed i had trunk lights today... mine dont come on either. I was going to check it out tm
Old 10-30-2008 | 02:06 PM
hotgrass's Avatar
mine too
Old 10-30-2008 | 02:25 PM
myxyzxo's Avatar
SoCal Crew Member
Open trunk, then turn on hazard lights. They should come on.
Old 10-30-2008 | 06:03 PM
joshuo's Avatar
^ nope, I tried that. It wouldn't make sense anyway.
Why would you need the courtesy lighting in the trunk ONLY when the hazards are on?
For those people with the same problem, when your trunk is open, does your HUD say 'trunk open'? I'm pretty sure it should.
That leads me to believe there is a microswitch in the lock that is stuck on 'closed'.
Yay, Nay?
Where is it?
epiphysis
07-26-2011 12:47 AM
stuck amals
12-28-2010 07:29 PM
MartinCieslak1
09-30-2010 03:26 PM
gioinnj
05-06-2010 11:32 AM
exequiel3k
09-13-2009 06:47 PM
