trouble with turbo XS hpbc
Old 02-06-2008 | 12:47 AM
eliTTe's Avatar
Default RE: trouble with turbo XS hpbc
ORIGINAL: zero388
I had it were it was working fine it would peak at 15 and hold at 14. Then I tried to increase it a little bit and it would peak at 15 then drop all the way into vaccum. Was this happening to you Lucas?
never went into vac. but the boost would surge up and down between 0 and 10 psi.
  #72
Old 02-06-2008 | 12:51 AM
cincyTT's Avatar
I'm make believe
not to offend anyone, but its really not that tough to follow the directions, pull vac lines and install them on the mbc. Should take all of 10mins to setup the mbc, install, and tune the mbc.
  #73
Old 02-06-2008 | 12:59 AM
zero388's Avatar
you didnt offend me but its not the directions that get me, its the mbc working for 5 mins then peaking and immediately dropping into vac
  #74
Old 02-06-2008 | 01:00 AM
cincyTT's Avatar
I'm make believe
have you checked to see if the brass fitting holding the b&s is tight? Still think your not setting the b&s tight enough.
  #75
Old 02-06-2008 | 01:05 AM
zero388's Avatar
you were right earlier when you said that I had to go somwhere and didnt get time to tune it comepletely so I just had to plug my N75 back in and I am just going to calibrate and start over tomorrow
  #76
Old 02-06-2008 | 09:27 AM
eliTTe's Avatar
I feel your pain zero... mine just messed up again UGHHH... [sm=sigh.gif]
thintzen
05-06-2009 02:00 PM
ceelos
09-16-2008 03:33 PM
Red_sapphire89
9
05-09-2008 02:51 PM
Ergokinetics
04-26-2008 07:09 PM
Red_sapphire89
04-07-2008 03:01 PM
