Tranny (gear) oil change question
Old 05-23-2007 | 12:13 PM
timbo108's Avatar
Default Tranny (gear) oil change question
Changed out the tranny oil on my 6 speed Q. I went with Royal Purple MaxGear 75W90. I also drained the bevel box and cleaned the magnetic drain. Didn't see any fill for the bevel box; am I correct that the box is connected to the trans (fluid exchanges back and forth)? If so, should one re-check the trans fluid level after re-filling and driving a bit (would the trans level drop after fluid transfers to the bevel box)? The box only holds about a cup or so.
Results after a few miles, shifts do seem smoother (especially the 1st-2nd and 2nd-3rd), less notchyness and the syncho feels better.
Old 05-23-2007 | 12:16 PM
techbod's Avatar
Default RE: Tranny (gear) oil change question
you did it right, its not like the auto tranny where you have to fill then run the engine then refill again
Old 05-23-2007 | 12:20 PM
timbo108's Avatar
Thanks for the quick reply. Thought I'd check before I re-installed the @%#%#% belly pan. Only headache with thejob was getting the fill plug off without a 14mm hex. Used a double-nutted 3/8 bolt .
Old 05-23-2007 | 12:23 PM
techbod's Avatar
as it the tranny you wont need to go back there for a long time and well worth the effort
Old 05-23-2007 | 01:41 PM
MeanAudiA6's Avatar
i might try the royal purple next time.....have redline in there now. hopefully i dont find as many metal shavings in there this time..
Old 05-23-2007 | 01:43 PM
techbod's Avatar
metal shavings are normal and mostly from when it was new and running in ( the magnet is doing its job )
Audisciple
10-30-2012 12:34 AM
Donman19
07-04-2011 05:14 AM
sdboarder84
06-18-2007 09:50 PM
carguytt987
03-08-2007 11:41 AM
