Traction Light turns on and off Why
if you are not loosing traction and that happens. for example it goes on for a while then it turns off again, it is a bad abs sensor on one of the front wheels. i had that happen. sometimes i would just be driving and the light would come on, stay on for a period of time, sometime minutes sometime days and the just go off. part cost about 20 bucks. check your codes for abs sensor.
Use one of these...
Very easy. Remove wheel well cover and it will be staring you in the face. Really sounds like a nick in the wire...once in a while the right bump will connect them and then u will lose it again.
It'll look ugly, but no one can see it behind the plastic wall anyway. I used a priority mail sticker for mine.
