timing belt service.
RE: timing belt service.
ORIGINAL: beachchair
I'm doing them this weekend, I bought the 2 piece kit, and am not replacing the center bushing, as it is my unerstanding it is semi- permanent, and only meant to be replaced if damaged.
Don't know why anything about the kit would produce vibration.
ORIGINAL: DurTTy
I FYI expect low rmp vibtrations, regardless of how you want to play with the clutch it will still cause vibrations.
the ES dogbone insert that i got required a 20ton press to get it installed so, be prepared.
the reason you get vibrations is as follows: oem bushing = built to have play so that they absorb vibrations. (the energy of the vibrations absorbed by the softness of the rubber)
if you go stiffer that energy is transferred to the chassis so you get vibrations,
the same goes for the engine mounts.
and the dogbone mount needed a press cuz the bolt would not just screw in, i had to press the insert in so that the bolt would grab.
when the dogbone top bolt comes off two rubber peice inserts come out. there is a metal plate that sandwiches two of inserts. the oem isnerts are soft so you can just press it in with your weight and the bolt (legth) will grab the thread. (the inserts are pressed in and then the bolt will grab)
it was my experience that when the stiffer inserts are ready to be bolted,(which are the same as the oem need to be pressed in a little), you need a lot more force to press them in than just your body weight.
so we used a 20ton press that we use to pop wheel bearing out of hubs. and im telling you go to the dealer and get the stretch bolts will cost a grand total of 12$ CDN maybe cheaper is USD?
you can take dogbone out and bolt it back it, thats the no brainer. you can probably jack your car, take the dogbone out, take the inserts out, and if you cant easily bolt the new inserts in, get a lift to a local shop (most shops have press for wheel bearings) and pay them 5$ to press it, or you can kindly ask them, it takes less than 5 minutes.
ORIGINAL: DurTTy
Appreciate the info.
me and a buddy were albe to just press them together and get the screw to catch a press is not needed trust me
a table vice might be all that you need if you dont have a buddy to help
ok, i got my car back yesterday and all i can say is d*mn. it seems to pull a lot harder with the new plugs. the revs seem to come on a little faster with the new lightweight pulley but nothing major, just a slight difference but noticable. the new dog bone bushings seemed to make a big difference in the shift feel, shifts seem smoother now- not as clunky as they seemed before. the only time i've noticed any vibrations is when i let the revs drop too low in second, it seems to vibrate a little more than before, but other than that no vibrations at all. all in all i am very satisfied with everything and i think it was well worth the money spent. i should have done the dog bone bushing months ago whereas my only real complaint about my car has been the shifter feel- now its fixed and im as happy as a ******* clam.
#19
ORIGINAL: DurTTy
i think its hit and miss, just like anything else
dont be surprised if you need a press, and be happy if you dont
As for the Dog Bone difference. That was the best $40.00 (which included new stretch bolts) I have spent on my TT. I like the stiffer ride, and more precise steering feel. I think it'll get even better when they have a chance to seat. Anyone thinking about it, should do it.
