timing belt service.
Old 01-23-2008, 12:29 PM
twenty8red's Avatar
Default timing belt service.
Well my car is in the shop today having the timing belt service performed (ultimate kit from ECS)along with new plugs (NGK BKR7E gapped to .028), energy suspension dog bone bushings, and ECS light weight crank pulley. I can't wait to get it back this afternoon. Is there anything I need to watch for or listen for after having the timing belt service done?
Thanks
Old 01-23-2008, 12:39 PM
beachchair's Avatar
Default RE: timing belt service.
Let us know the difference in feel, if any, with the new dog bones.
Old 01-23-2008, 01:30 PM
MeanAudiA6's Avatar
dog bone is a great cheap upgrade
Old 01-23-2008, 01:38 PM
twenty8red's Avatar
that's what i hear. i'll let you know what i think beachchair.
Old 01-23-2008, 01:43 PM
MeanAudiA6's Avatar
i want someone to tell me how the VF engineering trans and engine mounts are...as well as the 034 motorsports street and track mounts
Old 01-23-2008, 05:42 PM
projlightning's Avatar
So, what are they charging you for all that work? I mean if you don't mind me asking...
Old 01-23-2008, 08:18 PM
twenty8red's Avatar
i'm not sure, i didn't end up getting it back today. i'll let you know tomorrow.
Old 01-24-2008, 08:41 AM
DurTTy's Avatar
I have a Dogbone moun. it is not going to make a HUGE difference.
will make power delivery a little crisper when you change the gear get on the gas. FYI expect low rmp vibtrations, regardless of how you want to play with the clutch it will still cause vibrations.
the ES dogbone insert that i got required a 20ton press to get it installed so, be prepared.
Old 01-24-2008, 08:59 AM
beachchair's Avatar
ORIGINAL: DurTTy
I FYI expect low rmp vibtrations, regardless of how you want to play with the clutch it will still cause vibrations.
I'm doing them this weekend, I bought the 2 piece kit, and am not replacing the center bushing, as it is my unerstanding it is semi- permanent, and only meant to be replaced if damaged.
Don't know why anything about the kit would produce vibration.
Old 01-24-2008, 10:53 AM
twenty8red's Avatar
i bought the three piece kit but i'm not having them do the cylindrical bushing either. i expect some vibration due to the fact that the new bushings are polyurethane and not rubber but i'm not really concerned about it.
Quick Reply: timing belt service.
