Which Timing Belt Kit dieselgeek or ecs or? darn shops
If you followed the MBC & Diode thread, I found my cover for the timing belt cover not latched and it has rubbed the belt, (not bad) but enough to warrant a new timing belt kit. Also even though I checked in with the Prevoius owner & the shop that did the work prior to my purchase. I dont believe the tensioner, roller, or Waterpump were replaced[:@]. The thing that makes me confident that the shop DOES NOT KNOW WHAT THEY ARE DOING is while I was talking to them they stated that the owner had always had serviced this car very regularly and had even done the timing belt before the service was due, the belt was done at 80K. Which is considerably late from what I have read everywhere. Also since I have had the car If it sits running it will go one mark past half on the temp gauge, on the HVAC readout trick on slot #49 I have seen it go to 103 degrees, it always go down to say 98. if I rev up the motor is seems to drop very quickly. so I fear there might be a broken or spun impeller. Anyways, I noticed the diesel geek kit seems to have a different tensioner, is this good or bad? The ecs has the Audi stamp right on the tensioner from pictures anyways. any good or bad about either? thanks
RE: Which Timing Belt Kit dieselgeek or ecs or? darn shops
Both kits are good. Technically the parts are the same. If, however, the parts are not sold to Audi, the manufacturer is supposed to grind off or remove any Audi logo on them.
$700-800 incl parts is within the range to be expected. Go for it. Just be sure they include the water pump and tensioner at a minimum. Thermostat is doable, but not really a part of the overall TB install.
I am going to do it myself I have rebuilt a handfull of engines,never any problems, I looked a t a couple of writeups online it looks pretty straight-forward. I did however check around, a local VW place quoted $650 for everything including Belt /tensioner/roller/waterpump/ thermoststat& housing. seemed decent, I asked about metal impeller he didnt seem to know. I think they use exact factory parts.I'm going to order a kit this week and probably do it early next week.
