Timing Belt Complete
Old 09-29-2008, 08:37 AM
225tt's Avatar
Default Timing Belt Complete
Did the timing belt this weekend and that is something that I never wana do again. No it wasnt that hard just time consuming. But everything is up and running. 58K miles down another 60K to go.
Old 09-29-2008, 05:13 PM
Wintermute's Avatar
I said the same thing.
Old 09-29-2008, 05:17 PM
MeanAudiA6's Avatar
yup +1
Old 09-29-2008, 06:26 PM
achTTung's Avatar
im a masochist, I sorta enjoy it now. ; )
I see it like a game and try to beat my best time every time. Done 2 full changes (water pump, etc), and replaced only the tensioner once, but that requires about 80% of the work anyway.
Old 10-07-2008, 05:16 PM
666 the legend's Avatar
.....So..?? How long did it take..?? since I have tuh do this PROJECT now..?? any pics...?? tricks..? special tools.....?? My girl has a 2002 tt and Im pretty damn sure the water pump took a crap......
Old 10-07-2008, 06:42 PM
Wintermute's Avatar
Overheating? Might be valve cover gasket.
Old 10-07-2008, 06:43 PM
achTTung's Avatar
First time, working on your own w/ no prior experience, but handy with a wrench, give yourself 8-10hrs.
If you're doing the thermostat as well (comes with the kit usually), add at least an hr for that. I fought with it the first time, now I'll just go ahead and remove the intake manifold, which gives you the room you really need to get the job done.
Use this, and related links. Probably the best done writeup i've ever seen.
http://www.amp82.co.uk/tt/timingbelt/
You're gonna get stuck juggling the motor mounts and belt tensioner, and actually getting the new belt onto the pullys. 'Tight fit' is a gross understatement. Motor mount and tensioner have to be removed and installed together, if you fit one in first, there isn't enough room to slide the other in. An extra set of hands (or a couple rolls of duct tape) come in real handy here.
Old 10-07-2008, 07:25 PM
..Its not FLOWING...So its gotta be the water pump......and valve cover gasket..?? hows that make it over heat..??
Old 10-07-2008, 07:26 PM
Aww God.....!!..lol.....I have " 0 " patience wit diss crap too.......I gotta re-think this..!!
Old 10-07-2008, 07:53 PM
achTTung's Avatar
Approx $300 to do yourself, or anywhere from $750 to $1200 for a shop to do it.
Think on that too!
Quick Reply: Timing Belt Complete
