ticking noise??
RE: ticking noise??
depends. Most times it is just valve chatter. But when it starts sounding funny, its often time the cam tensioner. If you have a nonVVT car its cheap to replace (under $100 from ecs i believe) and if you have vvt, its pricey as hell ($700 on ecs).
RE: ticking noise??
The fuel injectors are kinda loud, but its easy to stick your ear down next to them to see if thats the source of the noise. Otherwise, there really shouldn't be any noise that stands right out. I'd say the hydraulic lifters are next in line for noises, you can try running a heavier oil to see if they quiet down if you think its something other than the injectors.
