sway bar bushing help
Old 11-13-2007, 12:17 AM
auditech79's Avatar
Default RE: sway bar bushing help
Just call the dealer parts dept. with your VIN, they will tell you the part number. There is also a TSB for the bushings that says they will replace the swaybar and the bushings.
Old 11-13-2007, 01:52 AM
proxeyed's Avatar
Dumb question, but will they do this for free even if the car has been out of warranty for so long, and I do not have service history?
Old 11-13-2007, 08:10 AM
JettaRedII's Avatar
This has probably been answered, so I'll repeat it.
The rear bar is 14mm. Get the Neuspeed 19mm bar which comes with polyurethane bushings. The front bar should be 20mm, but measure it with calipers. I think TTSTUFF has poly bushings for about $50. They are definitely worth it.
No, you do not need to remove any linkage to install the bushings, but you should remove the wheels to make it easier. The front are a pita, but you can do it.
Good luck.
Old 11-13-2007, 12:51 PM
heinz57's Avatar
how are they a PITA? just because of the restricted spaces?
Old 11-13-2007, 01:24 PM
JettaRedII's Avatar
Yes.
Old 11-14-2007, 07:13 PM
proxeyed's Avatar
Alright so I've tried getting through to the dealer serivce dept.. and no luck. So maybe you can give me an answer. Will a dealer cover the Swaybar TSB, even if I bought used, private party, TT with no warranty? Or will I have to pay to have the dealer fix it for me?
Old 11-15-2007, 01:51 AM
themysteryman83's Avatar
A TSB is not a recall, fyi. I believe they will cover it if it's still under warranty, but if not then it's up to you.
  #18
Old 11-15-2007, 12:53 PM
heinz57's Avatar
can you measure anywhere on the front sway bar to get the overall diameter? or do you need to measure the area where the plastic sleeve goes over - with the sleeve taken off?
  #19
Old 11-16-2007, 10:55 AM
I emailed TTStuff and they wrote back saying that the correct one for my car are the 20mm ones. So that answers that.
shutupnshift04
11-13-2012 08:14 PM
samm86
04-29-2011 01:29 AM
kevace1
11-13-2010 12:37 PM
vegastt
08-24-2008 11:13 AM
B5luver
12-18-2007 12:42 AM
Quick Reply: sway bar bushing help
